Текущее время: Ср дек 17, 2025 10:34 am
Начать новую тему Ответить на тему  [ Сообщений: 42 ]  На страницу 1, 2, 3  След.
 Заголовок сообщения: Avensis 2001-06 (T22-Facelift-model) Steering Noise. (Video)
СообщениеДобавлено: Чт окт 13, 2011 11:21 pm
Hi,
I don't speak Russian... (I'm from Holland.) :oops:
I have a noise in my steering!
Does someone know what to do?
I have lubricated almost everything...
Here is the video.
http://youtu.be/C9-Qr4P62YY
You can reply in Russian!!
 Заголовок сообщения: Re: Avensis 2001-06 (T22-Facelift-model) Steering Noise. (Video)
СообщениеДобавлено: Пт окт 14, 2011 12:01 am
Where the pedal, the steering shaft is anther. it creaks, sprinkle a little WD-40
СообщениеДобавлено: Пт окт 14, 2011 1:19 am
...or silicone lubricant :D
СообщениеДобавлено: Пт окт 14, 2011 4:15 am
Thank you, but i was there already with some Teflon :D spray!!
The sound is not coming from there but higher up the steering column.
We thought it was the airbag-coil, but it wasn't because we testdrove without the coil and the noise was still there! (After that we had to reset the computer because of airbag failure ofcourse.)
I was at two Toyota-dealers:
-The 1st one said it's the steeringrack that needs to be replaced. (Common Avensis problem!)
-The other one said it's the steeringcolumn that needs to be replaced. (Also common Avensis problem!)
But i still think that it can be solved with some grease somewhere... but the big question is: Where! :D
The sound is like rubber on rubber /or rubber on glass /or rubber on metal.
The sound starts after some kilometers of driving. (So, it starts after something gets warm and starts to rub against something...)
But i will try some wd40 again (Maybe it was not enough...), between the intermediate shaft and grommet...
I will let u know!
======== google translation =======
Спасибо, но я был там уже с некоторым тефлоновым брызг!
Звук не оттуда, но выше, до рулевой колонки.
Мы думали, что подушка безопасности катушки, но это было не потому, что testdrove без катушки и шум был все еще там! (После этого нам пришлось перезагрузить компьютер из-за отказа Конечно же подушки безопасности.)
Я был на двух Тойота-дилеров:
-1-ый сказал, что это steeringrack, который нуждается в замене. (Common проблема Avensis!)
-Другой сказал, что это steeringcolumn, который нуждается в замене. (Также распространенной проблемой Avensis!)
Но я все еще думаю, что она может быть решена с некоторыми жир где-нибудь ... но большой вопрос: где!
Звук похож на резину на резиновых / или резины на стекле / или резины на металл.
Звук начинается после нескольких километрах от вождения. (Таким образом, она начинает чего-то прогревается и начинает тереться что-то ...)
Но я постараюсь некоторые WD40 раз (Может быть, этого было недостаточно ...), между промежуточного вала и втулки ...
Я буду пусть знает!
Последний раз редактировалось Bocaj Пт окт 14, 2011 8:34 am, всего редактировалось 1 раз.
СообщениеДобавлено: Пт окт 14, 2011 7:25 am
Bocaj
Hi! Helaas, uw Engels niet normaal overgebracht naar de electronische vertalers aan, doen veel niet begrijpen. Gebruik bij het posten van berichten elektronische vertaler. Bijvoorbeeld Google. En op het onderwerp, de vloeistof aan de macht veranderd?
СообщениеДобавлено: Пт окт 14, 2011 8:30 am
SoSed60 писал(а):
Bocaj
No, the powersteering fluid has not been changed. I have heard about additives but not tried it yet.
СообщениеДобавлено: Пт окт 14, 2011 2:40 pm
У меня так же только в конце хода руля,что вправо до конца что влево!? Поменять жидкость для начало!? КТо что льет!? Из-за чего еще может быть!? Насос ГУРа!? Как проверить?
Avensis,седан, 1998г, темно-зеленый,4A-FE, МКПП С50
СообщениеДобавлено: Пт окт 14, 2011 4:38 pm
If sprayed some wd-40 there but no result.
Are there in the steering-column some noisy rubbers who are getting dry after the years go by?
СообщениеДобавлено: Пт окт 14, 2011 8:10 pm
Так это резиновый пыльник рулевого вала при выходе его из кузова скрипит! Совсем недавно у меня было тоже самое. Смазал вал в этом месте консистентной смазкой - и все прошло! :)
СообщениеДобавлено: Пт окт 14, 2011 8:27 pm
это нормально.
СообщениеДобавлено: Пт окт 14, 2011 8:38 pm
Посмотрев видео, я понял скрип в салоне, а не под капотом!?
Звук похож на трение РЕЗИНЫ. Я обвел красным. Нужно очень хорошо смазать.
Эта проблема была у многих, у меня тоже скрип был после 30 минут.
СообщениеДобавлено: Пт окт 14, 2011 8:50 pm
What i can do next is to spray it again but now from under the hood. (The otherside.)
I can also try to disassemble that thing to have a closer look!
СообщениеДобавлено: Пт окт 14, 2011 8:56 pm
You can get under the steering wheel and pedals to the ear. Hand turn the wheel and listen to it squeak or not.
I have a squeak was gone immediately, and got used to have passed. lithologic oiled.
СообщениеДобавлено: Пт окт 14, 2011 9:01 pm
I can tell you that there is not a squeak there!
But, i have been told that sound travels up from the bottum of the column to the steeringwheel...
When i listen with my ear it still sounds as if it comes behind the steeringwheel...
СообщениеДобавлено: Пт окт 14, 2011 9:17 pm
I'm thinking about to take off the steeringwheel again and the airbagcoil, ignition etc. to search again for the squeak.
